I turn off my truck is not gasoline pump
13 years 11 months before #25606 by manual-mecanica
I turn off my truck is not gasoline pump published by Manual-Mecanica
I turn off the truck by moving already changed the gasoline pump, only turns on the 3rd time or fourth that I turn on the switch, if you go but it does not turn on as if you do not inject gasoline but you already change your pump ... what can you have?
13 years 11 months before #25609 by manual-mecanica
Manual-Mecanica response on the Re: I turn off the truck is not gasoline pump
Hello how are you? It indicates the model and motor of the truck well, and there are see that it can be. Thank you
13 years 11 months before #25618 by manual-mecanica
Villager Model 1999 Motor 3.3
13 years 11 months before #25619 by manual-mecanica
Greetings, in this type of failure, the first thing is to scan the vehicle to detect if you have any fault code registered, and in case with your vehicle year 99 it is easy because it complies with the regulations of OBD II, it is not others to measure the fuel pressure, a poor pressure regulator can turn off an engine running, as well as an obstructed gasoline filter. Check those points and let us know. Luck.
13 years 11 months before #25621 by manual-mecanica
Also fix if it starts after you stop seconds how many, or minutes look good, how long it takes to go after you start the engine etc. And as the Compa says it would be good for you to check the pump pressure.
