Problems with Renault Clio 1.5 dci Expression 82CV
14 years 1 month before #26653 by manual-mecanica
Manual-Mecanica Answer on the Re-Renault Clio 1.5 DCI Expression 82CV
Well, these Renault engines are the famous K9K, celebrities because they do not stop giving problems if they are touched as a distribution and put it wrong about any circumstance, or advanced giving admission problems, or late giving problems in the escape. But the worst thing is not this, that it is corregible, the worst thing is that these engines when wearing camshaft with sentences in the tree (which is a hollow tube), if they have ever put it badly, the cam phase in its opening and closing to varied, this cannot be seen because they are degrees and a comparator clock is needed, and therefore it gives rows of roart The escape etc. etc I do not know if this is, but investigate if someone has touched it as a distribution and if so, there comes the problem.
14 years 1 month before #26655 by manual-mecanica
Well, a friend first in mechanical issues that is not that the worst that can happen to you is to cry your pockets.
Because of how little your problem is the arrival of fuel, you would have to make the diesel strangulator review, which is the one that lets the diesel pass, that as first, to show the injectors see how they are, pass it through the scanner see if it tells you that it has some kind of error.
In case I do not fail the scanner, I play it for the
gasoil
strangulator Volate (I tell you as it comes from gross) to the album that huge that is in the crankshaft that connects with the box) and has a mark on the cams
14 years 1 month before #26662 by manual-mecanica
Well, thanks to thess ... but look, I changed the EGR valve and I When I bought the Coxe I had the broken water pump and they put the pump and the distribution kit ... And it also coincides in the start and the noise that uncle the other day a clan was schedu And no longer sounded again ... you have a little guy
14 years 1 month before #26666 by manual-mecanica
Another reason why the distribution is not, if it were continuously, I do not affirm it sometimes and sometimes not.
To be able to tell you more it is actually that it would have to do with it but like you are an ocean of distance xD
14 years 2 days before #27721 by manual-mecanica
Well gentlemen forgive him for aber stop commenting. You can know some wire
