My Dodge Caravan has no strength to start
13 years 11 months before #25529 by manual-mecanica
I started with a fault that, when starting or rapidly accelerating, had no strength, as he was going. If the SUABE ACCELERATOR apartment, Normal Araca. I grabbed the normal changes slowly. The problem is when starting quickly. But as I burned little oil. I decided to repair the engine. They changed pistons, rings, metals, oil pump, bumps. Well everything about a general repair. And the 6 injectors, distrusting lid, rotor spark plug wires, spark plugs, gasoline pump, filters, filters. And remain the same. Now they told me that it can be the turbine of the transmission (the transmission was repaired about a year) they also began to turn on the spotlights of the board as if they were the emergency lights when I turn it on and do not go out they are always standing
13 years 11 months before #25679 by manual-mecanica
Manual-Mecanica Answer on the Re: My Dodge Caravan has no strength to start
What year is your caravan friend, probala without the catalyst to see how it reacts
13 years 11 months before #25687 by manual-mecanica
It is model 98 and has no catalyst
13 years 11 months before #25694 by manual-mecanica
Mmmm I saw that problem with the flow, but I don't know if caravan 98 brings it.
13 years 11 months before #25717 by manual-mecanica
You could explain a little more. I would add it to you
