Maf Nissan Sentra Air Flow Sensor 2000
14 years 2 months before #25427 by manual-mecanica
Maf Nissan Sentra 2000 Air Flow Sensor Published by Manual-Mecanica
Good night,
According to my mechanic, my Nissan Sentra 2000 is bad for the MAF air flow sensor and that's why it goes out, I look for them in the commercial houses and yonkers of Tegucigalpa and the cheapest is L.4200 in dollars are $ 220 really expensive, before buying it I need to clarify certain doubts, as knowing that it works or that another alternative I have, or how is I Recognize, SLS there I leave the photo
14 years 2 months before #25432 by manual-mecanica
Manual-Mecanica Response on the Re: Maf Nissan Sentra 2000 Air Flow Sensor
To begin with, I do not know what the sinking mechanics have so much experience in these vehicles but if you can make you turn off the one that does not serve the flow sensor, it can cause you to lose strength at the exit and until it thunders the spark if it does not work and most of the times it is not detected by the scora because the sensor generates and can be in the operating range but does not respond with the same speed as when it was good and clean. The manual specifies that this sensor generates between 1.3va 1.7 in minimal march. I have had a case in which I generated 1.53 and after a few seconds in progress minimal it went out. I try well before asking for a spare and if I am not sure I try one if I can get one borrowed. This is for it to work and because the scan does not detect if you have another alternative: if the Hyundai Accent sensor is the same only the connector changes but the lines are in the same position I do not know if there is there of this type of accent sensor but it can be used here cost between 75 to 125 new dollars and used with the defernce that the new one is Korean or Chinese and not all come good. Once they brought me a Ford F250 from Honduras here to El Salvador, so I don't know what so much experience they have in the electronic injection cars there, I hope your problem will be solved.
14 years 2 months before #25433 by manual-mecanica
If the engine is shaken and turn off, then if it's the sensor
14 years 2 months before #25434 by manual-mecanica
Here in Mexico it seems that it is cheaper and that car is used a lot, greetings from Hermosillo Sonora Mexico, if you want I find out how much you get your Savez crazy.
14 years 2 months before #25492 by manual-mecanica
Hello, then the truth here the mechanics learn in the practice and the most common car here are the toyotas,
I already have the new Sendor and I look at a diode I think so it is called that I RECive
