Nissan Xtrail 2003 Distribution chain Snido
14 years 2 months before #25159 by manual-mecanica
Manual-Mecanica Response on the Re: Snido Distribution Chain Nissan Xtrail 2003
Of course you should know that the chain carries a hydraulic tensor that works with engine oil uses a 10W40
14 years 2 months before #25161 by manual-mecanica
Hello friend, try to purge the oil circuit that carries oil to the tensioner, the air is highly compressible so it takes a few moments to raise oil pressure and tighten the chain. I am your dispute of any doubt or
14 years 2 months before #25202 by manual-mecanica
Do you have hydraulic regulated? I happened to be losing pressure for an irregularity in the regulator of another vehicle.
14 years 2 months before #25209 by manual-mecanica
The best thing you can do is change the complete chain game, pine nuts, tensioner and skate.
14 years 2 months before #25235 by manual-mecanica
This noise in the chain is normally produced by a pressure loss, it could even be the oil filter because they bring check vulvula or something that retains the oil in the filter when the engine is off, if the chain is stretched it produces that too ... we proceed with the filter put the original. Seeing is cheap this test ,, a father of ours and that's
