Ford Taurus problem
14 years 4 months before #25030 by manual-mecanica
Ford Taurus problem posted by Manual-Mecanica
Hello everyone, greetings from Venezuela, I am writing to you for the following I have a for Taurus 98 and the problem I have is that from a P1260 code this blockade would like to know if someone of you knows how to unfold this code since with the scanner it is not possible or if you know any program or have a manual of this type of car since here in Venezuela there is no reason why the car is imported very much thank you very much thank you very much :(
14 years 4 months before #25031 by manual-mecanica
Manual-Mecanica Answer on the Re: problem with Ford Taurus
Good night, friend best explains the problem maybe you can help you here those cars abound, Texas
14 years 4 months before #25051 by manual-mecanica
Here in Chile they look very little but if the computer is blocked there are people who unlock them forever and you use any key, but here I know where in your country no, luck, there is a program called immokiller is on the Internet but you need a cable compatible with your eprom to be able to enter I have never occupied that program so I don't know how effective it is, luck
14 years 4 months before #25139 by manual-mecanica
Hello friend Kikemec and the connector has to be from a lapto to the car connector of the car I suppose I really and apologize for not seeing responded previously
14 years 4 months before #25141 by manual-mecanica
Hi Dayton, I tell you the car, it will take it to repair the automatic transmission the mechanic when it turned it on, the terminal of the positive battery immobilizer and well there is anything that turns on that you think about that and if there is any way to turn it on and thank you very much for answering greetings
