Lubricant of the Skoda Fabia address ???
13 years 11 months before #25026 by manual-mecanica
Lubricant of the Skoda Fabia address ??? Posted by manual-mecanica
The question is very simple, just like the problem. But the way I solve it I don't like anything. The Skoda Fabia of a client lacked liquid in the assisted direction, and by wanting to complete the level I notice that the liquid did not have the color or the viscocity generally have that is to say red. And since the client is like Cascarabias I told him that he did not have the dexroniii lubricant for hibraulic direction but that he did not meet the characteristics that he needs that vehicle andq could get that lubricant in Skoda's commercial house. My question is what a difference has that yellowish and little viscous lubricant who had the vehicle, with the red that I offered him ??? And what type of lubricant is, and what cars do you occupy ??? I thank you in advance, X the Niñeria : Whistle:
13 years 11 months before #25033 by manual-mecanica
Manual-Mecanica response on the Re: lubricant of the Skoda Fabia address ???
Hello, here I pass several times that add anything to whatever it
is normal for them to put fluid of the common type brake because the brake is hydraulic as well as the direction
also the brakes carry special oils and add what they have at hand
must always be prevented, take into account that the last one that kisses it is to blame
13 years 11 months before #25034 by manual-mecanica
Hello, the subject I did, I began to read there and as a summary between the dexron® 2 and 3 there are only improvements wave less foam, better quality, less oxidation, the color is to differentiate them I suppose, now if you are going to put red one that came with yellow, it looks ugly for the client so if you change it, that it is complete, and explain that the color is to differentiate properties, which in the end Everything, in any case, while you can keep everything original and partner with the requirements of each machine is the best
13 years 11 months before #25037 by manual-mecanica
Hello..In Costa Rica, the direction oil has an almost transparent yellowish color and that of trans. Automatica is red ...
13 years 11 months before #25038 by manual-mecanica
Auto Data recommends Pentosin Chf 11s 202 which is a synthetic oil so I eye with the matter ........
Hydraulic & Power Steering Fluids
Questions About Shipping? SEE OUR TURS & CONDITIONS Page.
CHF 7.1, CHF11S, and CHF202 are Are High Performance Hydraulic Fluids Formulated for Central Hydraulic Systems Such As Power Steering, Rear Axle Steering, Level Control, Hydro-Pneumatic Suspension, and Shock Absorbers.
CHF 7.1 IS A MINERAL OIL BASED FLUID, WITH A RANGE OF OPERATION FROM -40ºC TO +100ºC, AND IS LIGHT GREEN IN COLOR.
CHF11S AND CHF202 ARE SYNTHETIC OIL BASED FLUIDS, with A RANGE OF OPERATION FROM -40ºC TO +266ºC, AND ARE DARK GREEN IN COLOR.
Pentosin Hydraulic Fluids are made in Germany, and are suppplied in a 1 litectle (1.06 quarts).
Pentosin Hydraulic Fluids Are Suitable for the Following Applications:
Chf 7.1: Audi/Volkswagen (1984-1989)
BMW (1987-9/1991)
Volvo (1995-1998)
Chf 7.1 is equivalent to before Oe Numbers:
BMW 81 22 9 407 549
Pentosin Chf 7.1 Should not be Mixed with Chf 11s,
Chf202, OR ANY OTHER HYDRAULIC FLUIDS. However, Chf11s
or Chf202 can be replaced for chf7.1 as an "upgrade"
if the system is flushed and refilled.
CHF11S: Audi (1990-2006) TL52 146.00
BMW (9/1991 ON); All Beginning with Model E32
Chrysler Crossfire 05127381AAA
Dodge Sprinter (All Years)
Mercedes-Benz (Staggered S-Class Models From 1996 on)
Mini (2002 On)
Nissan (1994 ON)
Porsche (1995 on)
Rolls Royce
Saab 900 Coupe (95 ON); 900/9000
(97-98); 9-5 (98 ON)
VOLKSWAGEN (1990-2006) TL52 146.00
3/1998 ON)
CHF 11S IS equivalent to these oe numbers:
BMW 83 29 0 429
576
PORSCH but do not mix with pentosin chf7.1 or any other hydraulic oils.
CHF202: Audi (2006 ON) TL52 146.01
Porsche Cayenne (2005 ON)
SAAB (
2006 ON) Volkswagen
(2006 ON)
146.01 Volvo (2002 ON)
CHF202 IS equals Compatible with Pentosin Chf11s, But
do not Mix with Pentosin Chf7.1 or Any Other Hydraulic Oils.
IMPORTANT Note ON FLUID COMPATIBILITY: If vehicle spectifications state chf7.1, chf11s and chf202 can be replaced in place of, but not mixed with, chf7.1. If vehicle spectifications state chf11s (or chf202), do not replace with chf7.1. Chf11s and Chf202 are full and mixable. PENTOSIN CHF FLUIDS SHOULD NOT BE MIXED WITH ATF FLUIDS. Always Check Your Owner's manual to confirm the correct fluid is being used for the vehicle.
Pentosin Chf7.1 Hydraulic Fluid
A Mineral-Oil Based Fluid for Hydraulic Systems Including Power Steering, Level Control, and Hydropneumatic Suspensions. Applications: Audi/Volkswagen (1984-1989), BMW (1987-9/1991), Volvo (1995-1998). Green Colored Fluid. You eat in a White Can with a Green Cap.
Price: $ 17.99 Stock #: Chf7.1
QTY:
Pentosin Chf11s Hydraulic Fluid
Synthetic-Based Fluid for Hydraulic Systems Including Power Steering, Level Control, and Hydropneumatic Suspensions. Applicable to Various Makes, BMW, Audi, Mini, Porsche, Saab, Volvo, and Volkswagen.
Price: $ 24.99 Stock #: Chf11s
QTY:
Pentosin Chf202
Synthetic Fluid for Power Steering Systems on Various Late-Model Audi, Volkswagen, Porsche, Saab, and Volvo Applications.
Price: $ 24.99 Stock #: CHF202
QTY:
We Accept Visa, Mastercard, Discover, Amex, and Paypal Payments
too fear for an oil!
