Citroen Saxo
14 years 4 months before #24989 by manual-mecanica
Citroen Saxo. Published by manual-mecanica
Hello everyone, I have a problem with my Citroen Saxo, it's a 1.6 8v. When it reaches normal operating temperature, between 2000 and 3000 rpm, the car jerks or seems to stall, and then runs fine again. It only happens under those circumstances and not always. I've changed the ignition coils and spark plugs, but nothing has changed. I also replaced the temperature sensors in case they were faulty and the ECU wasn't regulating correctly, but it's still the same. I'm hoping someone can help me.
Thanks a lot
14 years 4 months before #25004 by manual-mecanica
Manual-mechanics' reply on the topic Re: Citroen Saxo
Mmmmm is the problem half rare, it does not make any other symptoms, just the pull, if you leave the direct fan also does the failure?
