Peugeot Boxer HDI 2007
14 years 2 months before #24977 by manual-mecanica
Peugeot Boxer HDI 2007 Published by Manual-Mecanica
: UNSURE: Hello, I have a peugeot boxer hdi year 2007 and I have an `problem that nobody has been able to solve if someone who can help me or give indications that doing I am listening to,
well the problem is the next way the way moving the Check Engine and the truck sucks and the truck is not being able to advance anymore, and it goes out loses all the strength you have to stop waiting for a few minutes and re -lock up at that moment. To normality PORF minutes or hours and the same problem returns, already change the fuel filters, CKP sensor, the hoses are all well connected and they are not damaged, I clean the EGR valve, corner hose, new oil the truth has already has quite obfusca I appreciate this vehicle for this vehicle.
14 years 2 months before #24997 by manual-mecanica
Manual-Mecanica Answer on the Re: Peugeot Boxer HDI 2007
The best thing you can do is put a scanner, since the memoan computer and records the fault, that as if you do not change things to change and you will save money, according to the symptom I lean on the precion sensor of the ramp, is Cammon Rail that system, right?
14 years 2 months before #25006 by manual-mecanica
Hello thank you your answer and make 2 scanners only fuel fleeing ring and the mechanic only indicates Acer sensor changes,
now the sensor you say is the one that goes in the lifting pump?
thank you
14 years 2 months before #25007 by manual-mecanica
Friend, as the colleague says, the problem is in the fuel, the strange thing is that the scan throws you fuel, what is the P code associated with the fault?, The sensor that the colleague indicates is in the injection rail, it is at the center below with a red plug, the other that could give you failure is the one that is located in the high pressure pump, remember that if they intervene it, they are very careful, it is very careful. Note that it does not have particle, because it could come from the pump.
14 years 2 months before #25044 by manual-mecanica
This Keko is very right, give us the PC code that tells you, there is no rust that is called fuel leak, it has to be badly read that way we help you better, and if the sensor goes on the ramp and the other that Keko mentions is from the pump but it is a lift valve.
