C5 cooling fan problem
14 years 4 months before #24907 by manual-mecanica
Problem with C5 coolant fan. Posted by manual-mecanica
Good evening, I'm hoping someone can help me with a problem I'm having with the fan in my C5. It turns on when the temperature drops, but it doesn't turn off even when the temperature goes down, and it also doesn't turn off when I turn off the climate control. Thanks in advance.
14 years 4 months before #24918 by manual-mecanica
Manual-mechanics' response on the topic Re: Problem with C5 coolant fan
Look, you might have a problem with the temperature sensor; it has three wires. That's what makes the electric fan work. Also, check the black electronic box in front of the fan... One question: when the fan is on, does it run slowly or quickly?
14 years 4 months before #24950 by manual-mecanica
It's important that you provide a little more information, such as the fan speed (high or low). If it's not shutting off, it could be as simple as low coolant or a faulty relay. To test it, you need to manually activate it. If it has a temperature sensor, locate the sensor and bridge it. Disconnect the bridge and see if it stops. If it doesn't have a sensor, you can do it from the temperature sensor. Check it and let us know.
14 years 4 months before #24964 by manual-mecanica
Hi, I replaced the fan because the old one burned out. It works fine, it's fast, the only problem is that it doesn't stop, neither due to temperature nor when the A/C is on. I was told there's a fuse box on the front side that controls the fan. Thanks for your reply.
14 years 4 months before #24965 by manual-mecanica
Josepe 22 wrote: Hello, I replaced the fan because the old one burned out. It works well and runs fast, the only problem is that it doesn't stop, neither due to temperature nor with the A/C on. I was told there's a fuse box on the front side that controls the fan. Thank you very much for your reply.
