HELP CHRYSLER Voyager does not start
14 years 4 months before #24817 by manual-mecanica
Manual-Mecanica Answer on the Re: Helps Chrysler Voyager does not start
Hello Cobra Mira, the forists are not so equibocated, if it is in a state of emergency or robbe The avitaculo, now what was the fault of the Crysler and how disarmed it?, you repair it or someone else? Czech that is not equipped with a short external current, which seems to me that the problem goes there, see if they light the interior lights radios and things, to shorten the search field, the Crysler manuals in Spanish are very scarce, but in English it serves no problem.
14 years 4 months before #25074 by manual-mecanica
Hello,
unfortunately, the list of possible causes is very long
and so with such little information it is very difficult to guess what may be failing, if you have a little knowledge of electricity and
a
lot molten, if the connections of the fuses are lazy, it has happened to me that the fuse is fine but makes false contact, this is corrected by fusing the fuse's legs a bit.
But remember to isolate the failure and a lot of patience
we are to serve you
luck
14 years 4 months before #25076 by manual-mecanica
For me that you should start by saying that they have touched him in the repair to be able to get an idea that Voltages can be needed or where you should check.
