HELP CHRYSLER Voyager does not start
14 years 4 months before #24785 by manual-mecanica
Help Chrysler Voyager does not start published by Manual-Mecanica
Hello everyone, I am new in this forum and I would thank you if you could help me, I have a Chrysler Voyager, we are repairing it and during the process it has been blocked and now it does not start or turn on the picture of controls or anything. We believe that it can be a system of block K, we did not have knowledge of what we do not have the manual or d or of owner already k is a second hand and came without it.
If someone could help me very grateful. Greetings to all. ciao
14 years 4 months before #24786 by manual-mecanica
Manual-Mecanica Answer on the Re: Helps Chrysler Voyager does not start
It is likely to miss connecting cables that connect to the battery terminal.
Greetings.
14 years 4 months before #24788 by manual-mecanica
how are you.
You can download the manual from this same site.
These types of failures are generally general feed cables or fuses or fuse unions
get a test lamp and check the thick cables that are going to give the fuse box to the drums to be drilling that Aiga Aiga in the extreme doas
can also be a main earth of the battery to the motor (very thick) would help details for example if they turn on the lights or directions etc.
Informs how the matter is going. luck.
14 years 4 months before #24796 by manual-mecanica
Czech The following looks for a green color with red is the current of Ignition comes from the Shut Down relay if it does not reach you, the following the following the relay comes two currents one when opening the suicht the other I do not know if it is direct if you are both then you are missing the exitation of the computer. I did not see if you mention the year but if it is prior to the nineties, it brings fuse cables where the relays are. luck.
14 years 4 months before #24809 by manual-mecanica
The only manual found comes in English, if you knew somewhat where you can find it in Spanish ......
The cables are well connected to the battery, lights and anti -theft alarm work, the problem has to be some system of a block that tnga, because we have check the battery and it is fine, the implementation arrives but does not turn. So k I don't look at ... if you know something thank you very much ....
