Ford Ghia 1.8 Zetec
14 years 4 months before - 14 years 4 months before #24637 by manual-mecanica
Ford Ghia 1.8 Zetec published by Manual-Mecanica
Hello everyone I tell you, I would =)
Latest edition: 14 years 4 months before by .
14 years 4 months before #24645 by manual-mecanica
Manual-Mecanica Answer on the Re: Ford Ghia 1.8 Zetec
Hello, I had a problem similar to a Ford and it was the TP or (potentiometer) eye I do not say that you change it if you can try another would be the best and do not forget to check vacuum leaks in the engine in all its hoses and packaging. Wash the valve (IAC) with carbuclink and do not move the butterfly screw to the butterfly of the acceleration body. luck
