Problems with Daewoo Lanos Year 98 synchronous
14 years 2 months before #24661 by manual-mecanica
I tell you to take the car to an electrician and PS I checked all the sensors and they are fine, the current to the aljectors arrive perfect, try a coil and position sensor and everything is fine, I send me to check the computer, Stoy Buskndo another car equal but it is hard for me to get it since for what I see are counted the lans 1.6 here where I live, however on Monday I will go where a Mr. They are good or not .. the electrician tells me that if the computer is good, he will have to take out the entire branch to check it, ..
14 years 2 months before #24764 by manual-mecanica
I already went to look for the computer and everything is fine on that side, the electrician is going to get the complete branch looking for the fault .. Well I will be informing you of what you advise.
14 years 2 months before #24922 by manual-mecanica
Good night, I tell you that today the electrician with the fault, according to what I understood was that I reset the sensors I did not
14 years 2 months before #24952 by manual-mecanica
You're welcome friend, but as data the sensors do not prescribe the computer if, but the sensors never never, the only one that could be said that it is reprogram is the IAC, to give it the new memory, ask it well that iso.
14 years 2 months before #24968 by manual-mecanica
It is correct was the computer that reset because it did not send the signal to the sensors ..
