Problems with Daewoo Lanos Year 98 synchronous
14 years 2 months before #24579 by manual-mecanica
Problems with Daewoo Lanos Year 98 synchronous published by Manual-Mecanica
Good morning, my problem arises after the belt has failed and bend the valve, once that has been fixed; The car turns on and when it goes out automatically drowns, I have already changed injectors, valves, the position sensor ... before the fast lighting without any problem but now it costs to turn it on for what I said previously that it drowns that if once it turns on it does not fail normal work the problem is when I turn it off, I would thank who can help me ... I can assume that it is a failure of some electrical cable Perfect ...
14 years 2 months before #24593 by manual-mecanica
Hi Yofred.
It does not seem to be a serious thing, check how many degrees the spark jumps and synchronize it, preferable with lamp, clean the sensors that go to the carburetor and test again. Luck.
Miguel
14 years 2 months before #24599 by manual-mecanica
Hi Servilimit, thanks for the aid, because today I was just cleaning the connectors and checking the wiring well, I have not finished yet, I also noticed that I did not have a good ground connection the position sensor (replace the connector), I am just checking the rest to verify the whole system well, tomorrow God through try to see if it turns perfect and thus solving the problem, and the car is full injection but already discard
14 years 2 months before #24600 by manual-mecanica
Hi Servilimit, thanks for the aid, because today I was just cleaning the connectors and checking the wiring well, I have not finished yet, I also noticed that the position sensor was not good (replace the connector), I am just checking the rest to verify the whole system well, tomorrow God through try to see if it turns perfect and thus solve the problem, and the car is full injection but already discard the injectors ..
14 years 2 months before #24612 by manual-mecanica
I lean on the possibility that this bad set to point, that is, the distribution is left a little run and is behind. If, when the change commits the problem, the problem is the most logical to review, check the set -up and see. let us know how you are going.
