A needle that marks gasoline
14 years 2 months before #24452 by manual-mecanica
needle that marks the gasoline published by Manual-Mecanica
I have a Nissan Sentra Gxe B14, I filled it with gasoline but the needle only marks me 1/4.
I would like to know if I should get the buoy.
14 years 2 months before #24459 by manual-mecanica
Manual-Mecanica response on the Re: needle that marks gasoline
Hello, you will see, the fastest process is to disassemble the aphorador and verify with a tester the resistance of the enhancer's potentyter, once above it gives you the entire dough, intimidated that decreases the gasoline increases the resistance and lowers the needle. Straw it and verify with the bolla up at all if the needle rises greetings
14 years 2 months before #24472 by manual-mecanica
Thank you very much that God bless you
14 years 2 months before #24478 by manual-mecanica
Try to remember that there is always more than one possibility for the same fault, look for the float cable and roll it to the ground and see if the marker goes up if you discard the clock at the moment, apart from being bad the float example is made a perforation and enters fuel, it also gives a herroneous measure, a blow to the pond that defores its structure also provides a herroneous reading.
