Nissan Platina Failure is thrown out and turns off
14 years 2 months before #24450 by manual-mecanica
Ola I have a problem with Nissan Platina, suddenly it is thrown and turns off the CKP sensor, the CKP sensor is already checked in cold and at the time it goes out and the pressure of the pump is fine, it is also good that something else believes that this faya causes and that I need to check their comments their comments
14 years 2 months before #24501 by manual-mecanica
The one that the resistance does not tell you anything The signal generated can fail if you can occupy an oscilloscope to see the generated signal you can see why it fails. The other thing you can do is check the belt time if the fault is constant and then turn off, or check the temperature sensor. The coils have given me a lot of problem and they have left engines out of other workshops. The other thing I have seen is that the Kangoo CKP fails and passes the hot and cold tests and generates voltage but the vehicle does not always start and if it starts it goes out at 2 days and no longer starts with changing the sensor the problem is solved and this sensor is similar to not saying equal to that of the plate Fallas for false contacts.
14 years 2 months before #24506 by manual-mecanica
The big K4M engine problem is the coils in three cylinders have no strength and sudden
