Peugeot Boxer HDI 2007 Check Engine
14 years 2 months before #24441 by manual-mecanica
Peugeot Boxer HDI 2007 Check Engine published by Manual-Mecanica
Hello, I have a Peugeot Boxer HDI 2007 the problem that in motion comes on the Chek Engine and the low speed although it accelerates does not rise more than 70 there are times that goes out or I have to stop it on and wait a few minutes and then turn on again, and the scanning there is no concrete answer only talk to me of sensors and change the CKP sensor and the petrole
14 years 2 months before #24444 by manual-mecanica
Manual-Mecanica Answer on the Re: Peugeot Boxer HDI 2007 Check Engine
Hello friend, I had a similar problem with a Fiat Doblo Multijet. Lost power reaches 80 and it was everything. Look at the problem I had was the EGR valve stuck since charcoal accumulates, it can also be some vacuum hose, or some connection, of the hoses. It may be there for the problem. I hope I could help you with something. Hopefully solutions your problem soon.
