Toyota problem with the spark
14 years 4 months before #24418 by manual-mecanica
Toyota spark problem. Posted by manual-mecanica
I have a Toyota Hilux 2.4 1999 The problem is the following that one when trying the spark is supposed to leave long and blue is orange, what problem can it be ????
14 years 4 months before #24421 by manual-mecanica
Manual-mechanics' response on the topic Re: Toyota spark problem
Friend, it's clear you need to change the spark plugs, but one of the most likely causes is that they're fouled or wet. The fouling is simply because they've reached the end of their lifespan, and the wetness is because you might have a leak from one of your injectors (if your Hilux is fuel-injected) or improper jetting in your carburetor (if it's carbureted). This causes a rich fuel mixture. What you should do is change the spark plugs and see what happens.
I hope this helps, and good luck with your truck. Cheers.;)
14 years 4 months before #24422 by manual-mecanica
What's wrong with the vehicle? To help you, you need to describe the problem. Your ignition coil might be bad, but in a vehicle with a distributor, advancing the timing can improve it. That helps diagnose the coil issue, but just looking at the color doesn't necessarily mean it's bad if there's no leak and the spark is long.
14 years 4 months before #24428 by manual-mecanica
The problem is that it's consuming a lot of fuel, and it doesn't use a carburetor; it's fuel-injected and has no leaks. I've been told it could be a coil problem. How can I fix that?
14 years 4 months before #24432 by manual-mecanica
Check the condition of the airflow sensor. If it were the coil, you would experience instability at idle, jerking when accelerating, backfiring, or something similar. Sometimes they fail without throwing fault codes because the ECU only registers signals below the acceptable minimum or above the maximum value at certain intermediate RPMs; it doesn't detect fluctuations as a fault.
