Subaru cylinder cover disassembly 1.8
14 years 3 months before #24241 by manual-mecanica
Subaru cylinder cover disassembly imprint 1.8 published by manual-mecanica
Scholarship Know how to disassemble the cylinder cover of a subaru Impreza GL 1.8 Model 95
14 years 3 months before #24288 by manual-mecanica
MANUAL-MECHANICS APPLICATION ON THE REAL SUBJECT: SUBARU CYLINDER COVER
You must disassemble the front, so that you can access the distribution strap, the marks you take it out, then you take out the valve lid that you want to remove, disassemble the camshaft and remove the butt bolts, I usually take out the engines it is easier to work it outside but it can be done because, it is only comfort. To forget you must disassemble the admission and escape multiple.
