Nissan P1610 and P16FF fault codes
13 years 4 months before #35280 by manual-mecanica
Manual-Mecanica Response on the Re: Nissan P1610 and P16FF fault codes
Thank you very much for the info, I will study it and I write anything here.
Greetings!
13 years 3 months before #36315 by manual-mecanica
I have a problem with a Nissan Pathfinder 2002 I do not start the engine the code it shows is the P1610 I already did the off 5 seconds and on 5 seconds 3 times but it does not start. It has something to do that it was without the battery for two days ?????? I was only changing the valve cover joints and when I finished that I was going to turn it on, I hope they can help me and thanks for reading my problem I will be pending.
13 years 1 day before #38650 by manual-mecanica
Manual-Mecanica Answer on the subject Nissan P1610 and P16FF fault codes
Hello friend I have the same problem with a Nissan Quest 97 RD of US and because that same code shows me the P1610 that I can do and also before that happened not to changes and showed me the fault codes of the butterfly and detonation sensor that I can do thanks thanks
