Nisan Patrol Y60 brakes
14 years 3 months before #23636 by manual-mecanica
Nisan Patrol Y60 brakes published by Manual-Mecanica
Hello, I have problems with the brakes, you reduce some furrows that had the records and change the tacos and the brake master and now the car slows me down with the pedal peeing it to the bottom, before half of the pedal route, it stopped me well.
14 years 3 months before #23648 by manual-mecanica
Manual-Mecanica response on the Re: Nisan Patrol Y60 brakes
What is recess, rectify, twist?
14 years 3 months before #23657 by manual-mecanica
From what you say I lean on the option that bleeding to the brake system, you must purge it correctly.
14 years 3 months before #23658 by manual-mecanica
The brake master is the pump or not?
14 years 3 months before #23675 by manual-mecanica
If you refer to the mastervac with a master (in my country they tell him a brake or hydrobac) you may have to regulate the pin with which he pushes the central bomb. But you mean the central pump you may not have purged the system well. There are systems that have purge taps in various parts of the system, on the wall of fire, in some suppliers or in a small pump that brings a lever and a spring attached to the crown (differential) in the tracera part (I do not know the name of this. The other thing that you can check if you did not And the purge tap is down and never lava the pedal because the air is up.
