Mazda Protecta 1998 Box 1998
14 years 3 months before #23610 by manual-mecanica
Mazda Protecta 1998 Box Published by Manual-Mecanica
I have a Mazda protects from 1998, it has a 4 -speed automatic transmission, recently I made a complete repair, (Master Kit) I also change the oil pump. The problem that I have with her is that when he changes from one march to another, he does it abruptly (he feels the blow) and I don't know where the problem can be. Say someone can help me a lot. !!!
14 years 3 months before #23612 by manual-mecanica
Manual-Mecanica Response on the Re: Mazda Speed ​​Box Protect 1998
I don't know if you already scanned, because if you don't have fault codes, it's a bit more difficult to give a diagnosis without trying the vehicle. Sudden changes occur for many reasons. High line pressure, bad speed sensor, absence of signal signal or speed speed output signal. If the changes make them at the right speed and hit it could be line pressure, your first one you have to test the transmission and have the data of the manual in addition to being sure that not having much game when assembling the disc packets.
