Gearbox.
14 years 3 months before #23479 by manual-mecanica
Gearbox. Posted by manual-mecanica
Hello, I am quite worried, I have a quite a quite passage of KM, a few days ago, I notice that the marches do not enter the first and the second, it does not make any noise or scratch me but I have to play with the movements so that I can enter ... I had something similar to the first one and it turned out to be a kind of rod or that told me the workshop that did not fit well, last month I had to change the bonus of the clutch almost 200 euros and now this .. If someone can tell me what I can be, I appreciate it, greetings.
14 years 3 months before #23500 by manual-mecanica
Manual-Mecanica response on the Re: gearbox.
Do you say that the problem is not the clutch but that the gear selector? If so, you must check the blacke, abecés bend and it is hard to enter the march but it is like strange that they bend only because if, there is always a reason, and forced or something like that, you also talk about the first and second, the rest of the marches are fine? As to rule out a clutch kit problem, that is, disk press and thrust bearing.
14 years 3 months before #23502 by manual-mecanica
Hello, for everything you say it seems to me that the problem would be in a support .... But I also have to tell you that between the first and second there is a bronze washer (synchronization washer) that is the one who suffers the most with the daily use of all the car and I think that this is the anger,
make a case of its mechanic, comment this answer ... luck
14 years 3 months before #23606 by manual-mecanica
Hello, first you have to check the change selection system and change of changes if they are in good condition possible damage to the first and second brocce ring.
