He stops
13 years 11 months before #23351 by manual-mecanica
It stops published by Manual-Mecanica
Hello friend, I have a zx 1.4 Citroen.
13 years 11 months before #23352 by manual-mecanica
Manual-Mecanica response on the Re: stops
First I would like to know what you are called "low compression" of cylinder 1, compared to the other cylinders, of course, but ... how much do you have compression to know if the
second difference is significant: have you already checked the acceleration body?
13 years 11 months before #23353 by manual-mecanica
The compression is 30 I put an additive and up 60 the other 120, and I have not reviewed the body of acceleration, weighing that it is a cut ???
13 years 11 months before #23354 by manual-mecanica
The compression difference is very significant !!!!!!!!!!
That explains the unstable in reling but not that it goes out
I think that if you should check the acceleration body and ...
does IAC valve have? or is it electronic acceleration body?
13 years 11 months before #23356 by manual-mecanica
What happens friend is that when I started giving problems, the electronic injection, and put a carburetor, but follow the problem, before I worked with carburetor and had no problem stopping .....
