Front wheel problem of a 2005 Explorer
14 years 1 month before #23264 by manual-mecanica
Problem in the front wheel of a 2005 explorer published by Manual-Mecanica
Hi, I have a problem with a 2005 Rolling Normal Explorer, it is not heard but when you want to go out the rapid rapid carro, there is a noise
14 years 1 month before #23266 by manual-mecanica
Manual-Mecanica Response on the Re: Problem in the front wheel of a 2005 Explorer
Hello, what kind of noise is it ????
At what speed do it more or less ???
Or is it all the time ?????
14 years 1 month before #23267 by manual-mecanica
Good friend if the noise does when you crusate the wheel when you are taking a curve that means that the roller of the waiter as we say here in Venezuela to the front axis is damaged, it is best that it specifies well how the noise is.
14 years 1 month before #23268 by manual-mecanica
Let's see, if the noise is when leaving the inertia, what can be is that the dough or homocinetic bearing have problems, I would advise you to review the homocinetic first and then dismantle the complete mass of the wheel, and see what is what fails
14 years 1 month before #23274 by manual-mecanica
Depending on the noise, it can be the label, the tray, the bearing specifies the noise and if it makes any pull,
