Oil escape per crankshaft retainer, peug
14 years 4 months before #22800 by manual-mecanica
Manual-Mecanica response on the re: oil escape by crankshaft retainer, peug
Aldo is right first to clean to be sure where the escape comes from and second is also more less in the right thing, in general, Peugeot uses the bench one that is the first one from the box has the distribution, as a joint and if he wears some rubber cells on the side, but he also has a retain where the steering wheel of anyway will have to lower the box and if the fault are the side of the gum of the bench. Download only that luck bench, first Czech where it is.
14 years 4 months before #22804 by manual-mecanica
Hello friends, first of all my thanks for its integr, the most curious thing is that this problem began on a trip to the coast, which is a region of high temperatures, but then when returning to the cold climate the escape disappeared.
I know this is not logical but it was, in any case I will make some checks based on their suggestions. I renew my sincere thanks for their advice.
