My vocho drowns when starting
14 years 4 months before #22710 by manual-mecanica
My vocho drowns when starting by Manual-Mecanica
Good I have a 72 beetle is carburated and I present a fault that when accelerating is drowning and turns off and I have to leave it for a while and turn on with difficulty what could be ???
14 years 4 months before #22713 by manual-mecanica
Manual-Mecanica Answer on the Re: My Vocho is drowning when starting
Hello, it would be good that you gave more information, since a carburetor generally when drowning is in minimal or full power, not only when you start, if you can give more information it would be better, well, for solving the one who is drowning nececitas check the fuel passage, which closes well or not fooling any "garbage"
14 years 4 months before #22714 by manual-mecanica
Not the minimum does not go out but when I start and go like less than 1 km the accelerator and as if nothing and go out and I have to wait a while to turn on again they told me that it could be the condenser also that it was already damaged what it warms does not make its function
14 years 4 months before #22736 by manual-mecanica
A friendly consultation your spark plugs come out black very dirty or do they go well?, is that to rule out a fuel excess, if you have a fuel excess you can have three situations, one that the low throat does not close, that the needle is stuck or that the float is very high, now you have to check your pique pump can do that failure too. But I think it is a carburetor with the bad condenso, not the car, ha and cool Hojo the distributor and the rotor lid itself, see that the Fiat 147 had that corduroy the car was warmed and the rotor does not work the rotor nobody knows because they only did it hahaha luck.
