departure motor
14 years 4 months before #22640 by manual-mecanica
Departure Motor Published by Manual-Mecanica
Hello: I have a very urgent problem .. I have a Suzuki Vitara year 89 'is 1.6 and the starter engine makes a lot of noise in doing so ... I have already broken 2 starter engines and I do not know what is due ... the crown of the steering wheel is in perfect conditions and the Bendix is ​​8 teeth ... If anyone knows about this problem please communicate it ... from now on thank you ...
14 years 4 months before #22641 by manual-mecanica
Manual-Mecanica Response on the Re: Starter Motor
Hello, I think that it can be the toothpaste of the starter engine that is very thick and between very fair in the dentate of the motor steering wheel, or do not coincide very well between them, it is the only thing that I can.
14 years 4 months before #22649 by manual-mecanica
Hello Hellseitan.
First attends the suggestion of Lamauto, it is a probable cause, it also verifies the settlement of the engine in the housing when you adjust it, the misalignment produces that effect. Luck.
Miguel
14 years 4 months before #22675 by manual-mecanica
The starting is well not having major problems when installing it ... the point is that I am not sure if the original starter engine carries 8 0 9 teeth? Today I bought a new one but it is not original and made the same problem .....
14 years 4 months before #22687 by manual-mecanica
I tuebe a similar problem and what I did was put some small ones between the start and its accommodation to separate it a little gave me a little, but I do not know that noise is the one that does to you, you can also do another test if you want to rule out the wheel of the steering wheel, stop the car, and push it a little like ahead or back in a light march, then you give it to it if the bump decreases if it decreases if it decreases if it decreases if it decreases if it decreases if it decreases if it decreases if it decreases if it decreases if
