Corsa 1.3 error
14 years 5 months before #22192 by manual-mecanica
Error in Corsa 1.3 posted by Manual-Mecanica
Hello,
first of all apologize if this is not the appropriate place for my question.
I tell you ... I have an Opel Corsa 1.3 of 2005 and a few days ago I has lit the fault light although the car seems to work without problems. I have been looking and I have found that with devices such as ElM and a laptop I could know what happens to it and then erase the error.
Specifying I found an elM in this store www.ecuracing.com/multimarca/3-elm327-v13a.html . What do you think?
Greetings and thanks
14 years 5 months before #22194 by manual-mecanica
Manual-Mecanica Response on the Re: Error in Corsa 1.3
Hello, good day, ok I explain this is a team so I read very good but it has to do if your vehicle is obd 2 is a connect of 14 pins which I am not sure that in the corsa it serves but you have to check on the riflera and you will see a rubber cap you take it off and see if it is the same model in the quadrant ok now I explain xq It will turn on the box or an oxygen sensor I hope my help serves you
This equipment is very good to buy it is very useful so you will be more located that fault has your vehicle greetings
14 years 5 months before #22331 by manual-mecanica
Hello,
thanks for the answer. I've been looking and I think I already have the connector located.
I'm going to launch my order, I'll tell you how about ...
14 years 5 months before #22334 by manual-mecanica
Amigaso if the light of the check is caught and the engine is well then you have two causes the oxygen sensor or the temperature sensor especially in corsaes that is what is avitually fails.
14 years 5 months before #22337 by manual-mecanica
It can also be the speed sensor ;)
