Ford Couer Motor Endura Oil Pump
14 years 5 months before #22166 by manual-mecanica
Ford Couer Motor Endura oil pump published by manual-mecanica
Hello, the truth is that I am new in this forum, I need to know if I need to get the engine to change the oil pump since in cold the oil pressure light titrates
14 years 5 months before #22172 by manual-mecanica
Manual-Mecanica response on the Re: Ford Couer Motor Endura Oil Pump
Well first of anything it is not the pump is the oil pressure valve I explain if it were the pump you will do everything you say to the contrary because when it is cold there should be more pressure instead when this hot store will lower the pressure I would recommend cleaning the valve and that the connector is the connector so that there a good contact I hope that my help serves you
14 years 5 months before #22184 by manual-mecanica
Thank you very much x your advice greetings
14 years 5 months before #22187 by manual-mecanica
Could you tell me where is the oil pressure valve thanks
14 years 5 months before #22190 by manual-mecanica
It must be located or in the oil pump on one side or on the filter, block, but it has or a single cable or trees
