VW Gol 1.8 Curate Packaging Change
14 years 5 months before #21866 by manual-mecanica
VW Gol 1.8 Curate Packaging Change Published by Manual-Mecanica
Very good afternoon gentlemen.
I have a VW goal 1.8 and I had a problem of an oil leak in the engine. I realized that the cylinder head was broken because I saw that there was oil in the cooling container; I already made the Enpaque camio, check the projection of the butt change other components such as valves and other packaging. The car was well.
But the big problem is that I do not understand why I lost strength as 50% and I am worried and not that S must.
I thank you for your answers to this problem.
THANK YOU SO MUCH.
14 years 5 months before #21867 by manual-mecanica
Manual-Mecanica Response on the Re: Change of VW Gol 1.8 Curate Packaging
Good afternoon friendship, check if the time is well taken in the crankshaft and camshaft pine
14 years 5 months before #21870 by manual-mecanica
hello.
Check the distribution strap, if the height is correct, the tuning of the ignition system, and cylinder compression measurement.
luck.
14 years 5 months before #21913 by manual-mecanica
Knights thank you very much for your considerations and recommendations. I will put them into practice and make the respective reviews.
Thank you again
