Limiting effect, drowned power when accelerating hyunda
14 years 5 months before #22110 by manual-mecanica
Hello,
when I try to accelerate to take power, it stays as a retained and the Taist Voluciones also, it is as if it had a limiter. It happens to me frequently. They changed my clutch and soon, it seemed that he had gone again, then they told me it was because the clutch circuit had never been purged. They purged me and I had clutch again.
As they told the mechanic in the house, they would have to regulate the clutch after the purge and he told me, that maybe that happened to me for that reason.
But everything sounds a bit strange. What do you think?
Thank you.
14 years 5 months before #22115 by manual-mecanica
If it were for clutch the suven revolutions but the speed does not, I believe that you can have another problem if it is uncovered as melting and grabs speed then the escape line can be clogged either by the broken catalytic or dirt accumulated in the silencer or short fire, or some problem with the speed sensor or a badly connected earth, this started after the clutch change or was before.
14 years 5 months before #22123 by manual-mecanica
Well friendly friend The problem is not the box or the clutch Your problem is in Power sensor since these car does not have a MAF they put an oxygen sensor that is located in the Amission Camarin carries four cables and is subject with a screw if it is not in the camarin is in the acceleration body that is your problem I hope that my help serves you
