Limiting effect, drowned power when accelerating hyunda
14 years 3 months before #21733 by manual-mecanica
Hello everyone,
I have the next problem, I have recently changed the clutch kit, and the few km skated again. Apparently it was, the clutch fluid circuit was dirty. Of this a week ago. The fact is that for two days, I notice how the car accelerates, is as if it had a limiter or contained when accelerating, losing the reprís. This is above all, it shows when a march to give power to the car or when I go in 4th or in 5th I want to put it at 130 or 140 km/h.
I have looked at the air filter and spark plugs and although they could change, they are not to cause, I believe that situation. Every 20-30,000 km I usually throw in factors so I don't think they were dirty. I have called the house and they have told me that it could be a sensor that does not correctly warn of the crankshaft revolutions, but in short, it is already known that in the house, they are immediately in a hurry to talk to you about 'La Trócola'.
I am grateful for the response in advance.
All the best,
14 years 3 months before #21736 by manual-mecanica
hello.
I would like to know more technical information on your vehicle, call what a displacement model, mileage and everything you can contribute.
thank you
14 years 3 months before #21738 by manual-mecanica
Hello,
it is a Hyndai Coupé 1.6 gasoline 150,000 km.
Do you know what may be happening?
14 years 2 months before #22009 by manual-mecanica
Can the problem be in the steering wheel sensor do the crown? Remove the sensor and the hole puts air and try
14 years 2 months before #22033 by manual-mecanica
What is the symptom of the car, you will accelerate it and the revolutions suven but in vehicle it is not faster or is stuck and it stays like when you are going to advance and goals badly the change.
