Clio ignition problem
14 years 6 months before #21483 by manual-mecanica
Clio ignition problem published by Manual-Mecanica
I have problems with the ignition of a CLIO 1.6 INSECTION YEAR 98 I have already taken it to several workshops and none solve it to me. The car works normally and on occasions when I stop it then it does not start, it seems as if it does not have a current when it encloses seems to drowned. I have already changed several sensors but the problem follows. Please if someone can help me I would appreciate it
14 years 6 months before #21527 by manual-mecanica
Manual-Mecanica Answer on the Re: Clio ignition problem
That fault makes it often, or sometimes specific, well anyway the best that can be done in your case, it is the following when the failure takes out a spark plug or the coil ramp depending on what you are equipped only take it out of its place do not disconnect it then ask someone to arranke and see if there is a spark I say it because it has passed on several occasions with the clios that the steering wheel where the position sensor or magnet captor is pointed, oxidizes you to sand the teeth and problem solved. Test and luck.
14 years 6 months before #21529 by manual-mecanica
Check the fuel regulatory valve, give those symptoms of drowning, and the gasoline engine flies
14 years 5 months before #21681 by manual-mecanica
The CKP sensor disconnects and connects the sensor connector again
14 years 5 months before #21725 by manual-mecanica
Most likely is the CKP sensor. You just have to clean it if the problem persists check the fuel pump
