Citroen Xsara air conditioner
14 years 6 months before - 14 years 6 months before #21389 by manual-mecanica
Citroen Xsara Climatizer published by Manual-Mecanica
I have a problem with the air conditioner, when I press the launch button the light is turned on and sometimes the noise of the electromagnet of the compressor enters, but in most of the time it does not enter, what steps can I follow to locate where the problem comes from
Last edited: 14 years and 6 months ago . Reason: mistake, I put "motor" instead of "button".
14 years 6 months before #21443 by manual-mecanica
Manual-Mecanica Answer on the Re: Citroen Xsara Climatizer
Hi, it looks like the compressor, but if you put more car data you can help you better with schemes etc. leave some example.
eg Motor, Nr.de doors, year.etc.)
14 years 6 months before #21466 by manual-mecanica
Thanks for the answer, the car is my second car that I have recently bought to move through the city, it is an Xsara 1.6 gasoline with twelve years old, when it is heard that the compressor enters the air is cold but after a while I stop and then it no longer works, could it be gas load? I have been able to read in a forum that if there is no gas the compressor self -protects so that it does not spoil when it is without load.
14 years 6 months before #21470 by manual-mecanica
If at the beginning it puts cold air and after a while it may no longer be the gas load as you say yourself as long as the compressor function. A greeting. Fixer make a load that is not very expensive and then tell us.
14 years 6 months before #21471 by manual-mecanica
You have a climate or air with an air if you have air here you have the almost complete explodes of your car keep.
