Pontiac G3 2008 Cold start, wet spark plugs.
13 years 6 months before #33485 by manual-mecanica
Manual-Mecanica response on the Re: Pontiac G3 2008 Cold start, wet spark plugs.
It is very easy to change that packaging and that is probably your problem, it is a classic fault of the G3 and the bird, they are the same car, when the cables and spark plugs with oil jumps the spark to the outside and does not reach the engine, remove the escape and check it later
