Distribution piñones 423 distribution pine nuts
14 years 6 months before #20936 by manual-mecanica
good night.
I need help to know how I can put the distribution pinions of a 4236 perkins engine. If you can collaborate, I would appreciate them very much.
14 years 6 months before #20984 by manual-mecanica
Hi Vanhel.
I was damaged by the scanner and I have not been able to buy another, let's see if I can clearly explain how the piñones brands are going:
in the crankshaft you will find a mark that is two points each at the base of a pinion tooth, tour the crankshaft until pistons 1 and 4 are in the PMS. In the intermediate niñón (or crazy as we call it commonly) you will find three brands one that are two points in a row at the base of each tooth of the pinion and the other two brands are solitary points. In the camshaft pinion you will find a two -point mark in a row and in the fuel pump pinion there is a mark of a lonely point. The crankshaft mark (two points) must fit into the crazy pinion mark (one point). The camshaft mark (two points) must fit the mark of a crazy pinion point and the fuel pump pinion mark must fit into the two points of the crazy pinion. Recall that the maximum game between gear train teeth is .006 ". Luck.
Miguel
