I have an Ipanema
14 years 6 months before #21060 by manual-mecanica
Manual-Mecanica Answer on the Re: I have an Ipanema
I should check if it comes to the pump, if it arrives and does not work it can be the problem of the pump connector, which has the lazy terminals or I have already seen extreme cases that the pine pins of the pump connector by a false contact are heated and melted outside and in the internal part of the unit where the pump goes.
