I hope the repair goes well for you
, but from my point of view, I wouldn't recommend that job
since you might damage the engine more than necessary, and you could end up spending the money you were trying to save, and even more than you thought. It would have been better to replace the valves, check all the valve guides (in case they have too much play), valve stem seals (or guide caps, as the other person mentioned above), the head gasket, and thoroughly check the pistons.
What I recommend is that you go to a mechanic's shop and have them check the compression pressure in each of the cylinders (make sure they remove all the spark plugs for this measurement to rule out a blown head gasket or leaks in any of them due to improper tightening or problems in any cylinder due to the valves or pistons). The lack of noise in the engine does not mean that the work is in perfect condition since the valves and pistons are a very delicate part of the engine because they are the ones most subjected to the heat generated by the explosions
