Megane Airbag 1 of 96
14 years 7 months before #20054 by manual-mecanica
Airbag Megane 1 of 96 published by Manual-Mecanica
Hello everyone. I have been checking with the axone the airbag of a megane 1 of 96 and it gives me after erase several memorized failures the following failure. TASSEGERE PRESENCE TESTE, OPEN CIRCUIT O issue?
14 years 7 months before #20060 by manual-mecanica
Manual-Mecanica Answer on the Re: Airbag Megane 1 of 96
Hello, you will see the subject is that in some models it is not under the seat to mount a prestoner, it is to move the seat ahead or back creates some bad connections, there are two options or disconnects and connect with security or short the connector and splices directly because the one that generates the problem is the sib
14 years 7 months before #20064 by manual-mecanica
Hello. Thank you to answer. Probate to disconnect the pretensioner connector under the seat to see if it gave me the same failure but a different one came out in the diagnosis. (Open circuit in the passenger pretensioner)
