CORDOBA 1.4 16V
14 years 8 months before #19723 by manual-mecanica
CORDOBA 1.4 16V Published by Manual-Mecanica
Someone has an idea of ​​electricity, I have a Cordoba who does not reach current to the implementation of the small cable of the automatic, someone knows what the cable is the or has the electrical scheme ...
14 years 8 months before #19777 by manual-mecanica
Manual-Mecanica Answer on the Re: Cordoba 1.4 16V
Good emerald. Start by checking the contactor behind the closer or starter key, I have a Toledo and I already changed it 2 times. If it were not to check the fine starter cable, follow the hitch in the gearbox (under the battery) that is usually broken by Hay.
Have luck ...
14 years 7 months before #19861 by manual-mecanica
Ok, I already buy the small starter engine cable and it does not reach the current, the key arrives current later I have not looked, but the problem has to come from the wiring of the engine part, TB gives me an amazing motor I have thought of buying the entire wiring in a scratch and changing it, since the car leaves the owner parked for two years next to the side of the bird and in the part of the engine there are yet
