ACCELERATION PROBLEM POINTER 1.8 MOD 96
14 years 9 months before #19460 by manual-mecanica
Manual-Mecanica Response on the Re: Problem Acceleration Pointer 1.8 Mod 96
Hello, I tell you that this model has a problem with the rifle that causes saws in the injection and injection system on the other hand, set if the regulator pressure is at the value of 0.9-1 bar otherwise modify it something else that I have happened to me is that the return duct is covered and anything m
14 years 9 months before #19465 by manual-mecanica
I'm going to try thank you very much, and how do I modify the pressure?
The car starts well, in cold and everything there is no drama
14 years 9 months before #19491 by manual-mecanica
Hello people, I tell you: Parami The problem is not fuel, for the moment you say that the spark plugs come out very black means that it is burning badly and I do not think it is due to lack of fuel.
14 years 9 months before #19492 by manual-mecanica
Spark plugs and cables are new, the rifle we take it out and clean it and check the contacts. The truth is to think that it could be the ECU, although I do not want to think about what is hehehehe.
14 years 9 months before #19510 by manual-mecanica
The sound of the engine is the same even having the failure at low turns?
is the car carburation ??
