Check Engine
14 years 9 months before #19429 by manual-mecanica
Check Engine published by Manual-Mecanica
Hello everyone I have a problem, I see the check Engine in the Astra GSI 2.4 16V (exhaust emission system)
has 2 oxygen sensors in the escape forward of the catalyst and another after it but it does not have it to the catalyst in place a
pipe
. lack of catalyst? How can I do not the failure come out?
Thank you
14 years 9 months before #19432 by manual-mecanica
Manual-Mecanica Answer on the Re: Check Engine
Hi Tocayo. Look, what you did taking out the catalyst is an important problem, since those sensors that it has are the famous lampas zondas, which sensit the exhaust gases to regulate the injection. Exactly for this you appear the "check Engine" and consumes you a lot more fuel. Well I hope it serves you and you can solve your problem. I recommend that you place the catalyst again even if the escape does not sound so beautiful. luck.
14 years 9 months before #19433 by manual-mecanica
Hi Diego, if I bought it, without catalyst and with a silens tacho, but I will see
how
emul
14 years 9 months before #19474 by manual-mecanica
OLA FRIEND! I recommend that what you should do is scan it to know why reason the focus of the check. Now I want you to know that the catalyst its function is to reduce emissions and the oxygen sensor that goes after its function is to monitor the catalyst and does not affect the injection unlike the one before the catalyst.
14 years 9 months before #19929 by manual-mecanica
Thanks Diego, they told me that it could be a lack of mass that I see how much the alternator loads should be at 13.8 a14 volts, I do not know what you think of this
