consultation
14 years 10 months before #18964 by manual-mecanica
Manual-Mecanica Response on the Re: Consultation
I first check the state of the brake pads, the Roleman de Rueda and the homocinetica on that side.
14 years 10 months before #18965 by manual-mecanica
I probably be the bearing of the bushing of that wheel, raise that wheel and rotate it if the bearing is very bad you will hear it well. You can compare it with the noise of the other wheel if you lift it
14 years 10 months before #18967 by manual-mecanica
If that would be the most successful, it depends on the noise that you have if you do not release the tip of the internal fender, which with the wind of the speed bends and touches the wheel, it happened to me with a partner, it is a fairly serious noise, now if it is a slice are the rough or the semi axis, and if it is a more sharp squeak they can be the pills.
14 years 10 months before #19027 by manual-mecanica
He already fixed it, it was the support of the homosinetic, with a good alignment and balancing, problem solved, thank you all for the data ,,, the same serve
