Ford Mondeo takes to rise temperature needle
14 years 9 months before #18519 by manual-mecanica
Manual-Mecanica response on the RE: Ford Mondeo takes to rise temperature needle
Well, it allows me to have my dicrepancies for what you say about the thermostat since the addiction that the air is already tempered and the needle stays low, this still says that the circuit already open and is in recirculation but the air would come out cold
14 years 9 months before #18528 by manual-mecanica
@POLLILLA:
The Theme The Temmed has distinguished Use The most usual is that it refers to that it is neither cold or hot, therefore it is in the midpoint (Google source)
Our colleague "Sacapuntas" tells us that it does not lift the needle of the temperatua bunda as 8 to 10 min approx and that the air of the calfaction comes out temperate
which indicates that there is a further level of temperature. Avoter thermostat, which leaves the water constantly circulates and does not meet the function of maintaining an adequate temperature of work, if it observes well in my first response and said that to our colleague, and in the second I explain that it would happen in the opposite case and how to determine the opposite case with a good method to know if the thermostat (in a case of the problem that our colleague has)
14 years 9 months before #18561 by manual-mecanica
Thanks to Enzolugano and a moth for your help when I have some time I will change it, a greeting
