I already repaired was the MAP sensor thank you very much for
14 years 10 months before - 14 years 7 months before #18271 by manual-mecanica
I am checking a National Cirrus 2001 2.4 Ke was crashed and the vehicle is already repaired, the problem is running minimal, it turns off is automatic and it brings turbo and in the scanner I do not appear any code running does not go out. Turn off your hand
14 years 10 months before #18293 by manual-mecanica
Manual-Mecanica Response on the Re: Failure in Cirrus
Czech the IAC valve and acceleration body that are not dirty
14 years 10 months before #18294 by manual-mecanica
I already check the body and the valve and they are well even at times does not make the fault, and it seems that it was the gas pump but already check the pressure and this
14 years 9 months before #18811 by manual-mecanica
The MAP sensor checks, because that sensor causes you intermittent failures without registering any fault if it is possible to install one that can fsilitar of a unit that you know that it does not have a failure in the workshop I pass that problem because it did not always present the fault and noded codes and it turned out that the MAP was the one that caused it to go out or lose intermittently the power
14 years 9 months before #18818 by manual-mecanica
Hi, you could eat the empty lines of the MAP sensor empty and do not have empty leaks in the framework of the right side radiator
