PRESENTATION AND PROBLEMS WITH BORA 1.9 TDI
14 years 6 months before #17780 by manual-mecanica
PRESENTATION AND PROBLEMS WITH BORA 1.9 TDI Published by Manual-Mecanica
Good morning, this is my first message in the forum and I hope you can help me.
I have a Bora 1.9 TDI of 99 and it turns out that the courtesy light does not turn on with the front doors, the question is that
I do not know where the doors are the buttons of the doors since it began with the companion's door and a week later the driver does not work.
I await your help.
Thanks and greetings
14 years 6 months before #17793 by manual-mecanica
Manual-Mecanica Response on the Re: presentation and problem with Bora 1.9 TDI
It can be in the lower part of the beter of the belt or under the hinge of the same serca of the hood.
14 years 6 months before #17816 by manual-mecanica
Well, it seems that I have looked at the whole frame of the door and in all of it and I did not see it, that's why it was the consultation, would it be coupled to the xerradura?
Thanks anyway
14 years 6 months before #17818 by manual-mecanica
It is not very normal but it would be, I repair a bora but it was defeatiners, I want to have the same components, so I told you that you checked well, I have not had to see one that fences the lock, which does not mean that they do not exist, VE is not difficult to take the tapestries of those doors.
14 years 6 months before #17908 by manual-mecanica
Indeed, the problem has it in the lock. That car has the contactor in the lock block. If you do not work with either, it is that you will have both spoiled. All the best
