Motor failure
14 years 10 months before #17721 by manual-mecanica
Motor failure published by Manual-Mecanica
Hello good!
I have a 240 hp DXI Renault truck that when heated begins to fail until he stands.
It does not give fault code and the pumps and injectors have already been checked.
Thank you;)
14 years 10 months before #17726 by manual-mecanica
Manual-Mecanica response on the Re: motor failure
Hi, check that no air enters anywhere in the diesel circuit
14 years 10 months before #17729 by manual-mecanica
Thanks for answering
the diesel circuit it is reviewed and has no air shot. The problem is when the engine reaches its temperature that fails and stops, while no temperature takes the vehicle is perfect.
Greetings!
14 years 10 months before #17737 by manual-mecanica
Check the temperature sensor if it is fine, take out the thermostat and try it.
