Urgent help
14 years 10 months before #17722 by manual-mecanica
Manual-Mecanica Response on the Re: Urgent Help
Everything again. The problem originated from the disconnection of the ground cable that reaches the engine. As a result of this, after three failed items, the system was blocked and the Álfa Security Code had to be entered. What happened was that the check was lit. I solved the problem DWSCONECA THE BATTERY FOR A TIME.
I greatly thank you for your collaboration and I will be attentive to provide support in what can
cordial greetings
